still alive and kicking
Postby buggyryan » 26 Sat May, 2007 1:22 pm
hi guys its been awhile and i have missed all you nuts. my question is do any of you use the small factory sway bar on the front end or just disgard it and not use it. i am finally getting my front end re-assembled.i was thinking about using coilovers on the front end anyways
buggyryan
Postby David O' » 26 Sat May, 2007 2:00 pm
I would leave it on!
Postby buggyryan » 26 Sat May, 2007 2:09 pm
howdy dave. hey do they make a kit to put it back on or an upgrade to a better or stiffer setup. the little clamp pieces were wasted with rust so i cut them off and threw them away along with the nasty rubber.
buggyryan
Postby David O' » 26 Sat May, 2007 10:57 pm
Yea they do, I think I have a set, I'll look tomorrow.
Postby Bryan Porter » 27 Sun May, 2007 8:38 am
Throw it away leaving it off will give you a softer ride and less harsh over bumps by letting the front wheels work separately like a bump hit with right front wheel is not transferd to the left side by the bar but if you are going to road race leave it on.
Postby Bill K » 27 Sun May, 2007 9:20 am
David,
What would be the reason for leaving it on? I took mine off, and my car seems to handle just fine. I don't drive fast and hard, so maybe that's why my car still drives good.
Postby David O' » 27 Sun May, 2007 1:57 pm
It controls the roll tendencies in corners, but it is a personal choice.
