Lots of Parts
Sell or trade your buggy or parts here
Lots of Parts
Postby Heathwerner » 08 Wed Jan, 2020 11:07 pm
If any of you need any parts just let me know. I have accumulated quite a few parts over the years and would like to see them go to good use. I have them posted online for sale but for the buggy group i will trade for beer or whatever you have that I may need. Here is some of what I have:
6 volt flywheel with pressure plate and two clutches ( John, Richard)
chrome fan shroud - some scratches
swaybar with new bushings for link pin front end
dual port intake - all 3 pieces
link pin beam bearings - original still in boxes and hard to get
69mm rods
26mm oil pump
92mm jugs
92mm stroker pistons
adjustable pushrod tubes
link pin arms
beam bushings
link pin beam
throw out bearings
vw beetle windshield seal - new
original vw jack
throw out bearing shaft
Most of this stuff is used but in good shape. Im sure I have some other things I cant think of right now but if you see something you may need just let me know. I need to down size my parts department.
Re: Lots of Parts
Postby staggerwing » 27 Mon Jan, 2020 10:16 am
You need to keep ALL this stuff! But, if you have to let go of the “6 volt flywheel with pressure plate and two clutches”, I have beer. Also looking for an early throw out bearing.
Re: Lots of Parts
Postby Heathwerner » 27 Mon Jan, 2020 10:02 pm
I just want it to good use instead of ending up in a corner somewhere in anticipation that I may need it one day. I would rather see someone use it now and if need be I will acquire them as needed in the future.
Actually I have an early throw out bearing with about 2 miles on it.
Give me a shout when you get a chance. I know being retired you are super busy!
Return to Buggies and Parts For Sale
