Tow vehicle capacity
Postby GregR » 16 Fri Oct, 2009 12:03 pm
So I'm wondering.
If you have a buggy and trailer combo that weighs, say 2,000 lbs and you tow it with a vehicle that has a 5,000 lb towing capacity, what differences would you see if a different tow vehicle only had a towing capacity of 3,500 lbs?
That is, would it bog down more on hills, be a rougher ride, or ???
tow vehicle?
Postby Hawk » 16 Fri Oct, 2009 4:46 pm
All the above. And fuel MPG will be worse also when towing.
hawk, decker
Hawk
Postby Vee Dub Nut » 16 Fri Oct, 2009 8:34 pm
its mostly what your suspension is rated at handling...
a truck and car can have the same horsepower, but one can pull a lot bigger loads than the other. Braking capacity goes into the equation, but mostly the suspension/stability of the vehicle
1967 Beetle
2000 GTi
Vee Dub Nut
Postby Tom Kathleen » 17 Sat Oct, 2009 12:46 pm
When we have to tow, we have a 2002 Dodge Grand Caravan with the 3.8L engine. It is rated for towing 3000#, but the Manxter and landscape trailer is @ 3000#, and then the loaded van. It can do it, but slows way down on the hills. It is also on the 2nd engine. Buy a real tow vehicle, and make it easy. The next vehicle will hopefully be a used Penske 16' box van. Tom
Manxter #16 & FiberFab Buggy
Manx Club, CVA, SCCA & RBC
Tom Kathleen
Postby CoryN » 17 Sat Oct, 2009 4:45 pm
Mine will pull 10,000 I don't even notice the buggy when it's back there
Users browsing this forum: No registered users and 15 guests
