carbs
carbs
Postby buggyryan » 27 Mon Feb, 2006 9:50 pm
hey guys i was looking for suggestions and past experiiences on big single carb setups or dual carbs . and also any good or bad experiences with the new empi carbs
buggyryan
Postby David O' » 28 Tue Feb, 2006 12:06 am
All of the single carb setups, require some form of preheat to the carb, or they tend to ice up the intake manifold. This takes place whenever the outside temperature hits 52 deg. or lower.
The new EMPI carbs have the electric chokes, and they come in two sizes, they are the kadrons. The 40mm Kadron will pull up to 1776 cc., and the new 44mm kadron will pull up to 1900cc. I would still recomend that an air cleaner with the preheat be fabed, just to ward off the icing problems.
The single webers, do not have the chokes and tend to be trouble when you first start the engines.
Postby GregR » 28 Tue Feb, 2006 5:55 pm
I really like my dual kads......be even nicer if they had chokes.
