---As much as it makes me feel goofy, this is consuming my time because I am not 100% sure what I should do.
---I am not sure if I should go ahead and straighten the Frame Head, or replace the Frame Head. I spoke with a local guy who works for a Restoration shop that says it will cost at minimum of $500. and assumes that it would be more as they charge by the hour.
---I could buy & modify an OEM Chassis, but I will have to find one that has a Swing axle with a title. In addition I would have to get the 14.5” removed. When I did this with another Bug the cost was about $1200. If memory serves me correctly.
---I could bite the bullet and have a chassis built. Not sure what that would cost me.
---I also could buy a Hawkeye Buggies Chassis from a Joe. But it has a IRS and I have everything for a Swing Axle. So this would end up costing me close to $1000 plus.
---I’m simply not sure what I should do at this point; your input is not only encouraged I will found helpful. In fact that is why I posted this here.
---Here you can see that the driver side is about 7/8th of an inch higher than the passenger.
---This is from the top. The Driver side is pushed back about an inch from the hat. You can also see that a crummy hole was cut in the top in order to run the wiring by a previous owner.
---In this pic you can see that the Frame Head has been welded on.
