Aside from the problem I'm having with a stiff front suspension, hopefully to be remedied after the Brenham gathering, something else has surfaced regarding the stiffness of the steering.
Pulled the front wheels to have them balanced and when I went to put them back on, I noticed the steering was really stiff while the front wheels were off the ground. I did some checking around under there and It may be just tie rod ends that are causing the problem. Boots are bad on both and they seem a bit tight. I don't know if that's normal or not but I'll replace them tomorrow and see if that's the problem. Ball joints are firm. With T-rods disconnected, I can grab a wheel, apply push/pull pressure by hand to turn it, and both wheels seem a little sticky at first then they move. Once each wheel starts moving, rotation back and forth seems normal, without too much effort. Steering box moves freely.
At first I was thinking ball joints. I've read that some people are having trouble after new ball joints cause they don't fit right and are too tight. I sure don't want to make things worse than they are by putting in ball joints that are too tight.
Will post update after new tie rod ends are installed and road tested.
