New wiring harness
New wiring harness
Postby Greaph » 02 Fri May, 2008 3:57 pm
Well my new wiring harness came in today. Purchased from an EBAY store for $160.00 with shipping.
On first blush, the packaging is adequate, however, the instructions are not. They are incomplete at best. With a little electrical knowledge, and some common sense, installation should not prove too troublesome. All wire is color coded and labled the entire length of the wire. The fuse panel is 21 circuit (including the starter circuit) and utilizes Mini blade fuses. It comes with several male and female plugs, and the horn, and light relays, as well as the turn and hazard flashers.
In all, I am well satisfied. :)
This IS my sig......
Greaph
Postby CoryN » 02 Fri May, 2008 4:19 pm
You know that is probably the part of the build that scares me the most.
Postby Greaph » 02 Fri May, 2008 4:33 pm
I would be more than happy to help you with it ;-)
Greaph
Postby jspbtown » 02 Fri May, 2008 9:42 pm
Don't forget your big spool of black ground wire!
I used a similiar style harness but with fewer circuit.
Are you going to be running some big accessories? 21 circuits gives me plenty to play with!
Postby Greaph » 03 Sat May, 2008 9:31 am
Biggest accessories will be the lights (offroad lights, 2x 100 watt, and 2x 35 watt HID driving).. the stereo wont be all that much (I dont intend to run any amps or subs). I just couldnt pass up 21 circuits just in case I need them.
Greaph
Postby Aquabuggy » 03 Sat May, 2008 11:01 am
jspbtown wrote:Don't forget your big spool of black ground wire!
Did you put heat shrink over all your connectors or can you buy connectors that way?
Postby jspbtown » 03 Sat May, 2008 3:37 pm
Heat shrink wrapped them all individually.
Bough 4, 3 foot sections, of shrink wrap at the recent swap meet for the next project!
Postby Aquabuggy » 03 Sat May, 2008 4:14 pm
Looks good!
