what is it?????
what is it?????
Postby frootloops » 11 Sat Apr, 2009 11:31 am
help me identify the buggy It was recently brought to my attention that it might be a sandwinder ...but there is not the bump between the hood scoops for the id plate it is smooth.... I want side pods and I think they are pretty universal fit but I want to make sure!
They told me they fixed it! I trusted them to fix it! It's not my fault!... Hahn Solo
frootloops
Postby Texasbuggys » 11 Sat Apr, 2009 1:20 pm
post a side pic
Postby frootloops » 11 Sat Apr, 2009 4:26 pm
Side
haha that kinda worked out panaramic! :roll:
frootloops
Postby wildthang » 11 Sat Apr, 2009 8:09 pm
Hello Frootloops welcome to the club site Check out Corsair dune buggy on the Dune Buggy Archives site looks alot like what you have maybe this will help Ray
wildthang
Postby frootloops » 12 Sun Apr, 2009 9:42 pm
Thanks for the welcome! and I think your right in all the coffee cans I found a badge that is Corsair while I was diggin around today. thanks for the information now the other question will Texas buggys' pods fit correctly?
frootloops
Postby Jack Duncan » 12 Sun Apr, 2009 11:43 pm
Frootloops, even the side pods made for the body won't fit correctly. Figure on having to do some trimming and fitting on your own. That's just how it is. If your lucky, they will be close but not perfect. I noticed you have a lift under the body. You might want to get rid of that before you try to fit side pods, or you'll have extensive work to do. :)
Postby Rick » 13 Mon Apr, 2009 2:39 pm
Not for sure but looks just like mine and I was told it's a California Clipper.
Rick
Rick
Postby CoryN » 13 Mon Apr, 2009 3:12 pm
I was going to guess California Clipper too. Look at the dune buggy archives at www.dunebuggyarchives.com
They should be able to tell you for sure.
Postby wildthang » 13 Mon Apr, 2009 6:08 pm
The California Clipper has a very close resemblance but the clipper has a center hump on the hood and the tail section is a flip up style and no hump
P.S . I personally believe you can make Bobbies Texas Buggy side pods work on that buggy. All need some type of modification , but they all look at home when they are molded to the body.
wildthang
