Need Advice about buying a Harness
Postby yoursurfer » 29 Sun May, 2011 9:47 pm
I have been reading board and posts, need to rewire the buggy i bought to bet it going, shoud I buy the harness
Moore -AC971000
UNIVERSAL WIRE HARNESS WITH 6 PANEL FUSE BOX. COMPLETE WIRING KIT INCLUDES 6 PANEL FUSE BOX, FUSES, WIRE, ENDS, AND ELECTRICAL TAPE. GREAT FOR DUNE BUGGIES, MANX BUGGIES OR KIT CARS
or
Rebel Wire 8 Circuit Wiring Harness
$135.95 Buy Now
Rebel Wire harnesses are all assembled in America from American made components. The 8 circuit wiring harnesses is perfect for Hot Rod, Rat Rod, T-Buckets, or Custom applications that require only basic circuits.
Assembled with heavy duty SXL wire labeled every 6" and bundled for easy
installation. This kit has 8 circuits for lights, gauges, radio, motor and third brake light. Kit comes with easy to use instructions for Chevy, Ford or Mopar installations, dash light wire, neutral safety switch wire, fusible link, 1 1/4" rubber grommet for the firewall, and fuse block label.
yoursurfer
Re: Need Advice about buying a Harness
Postby CoryN » 29 Sun May, 2011 9:50 pm
Not that hard to roll your own but it does take some time
Postby GregR » 29 Sun May, 2011 10:55 pm
I've heard the universal harness usually ends up being redone by the end user. If you don't want to build your own from scratch (like Cory said, not all that hard for a buggy), the Rebel harness is probably worth the bucks. Even with that, expect to need to extend some wires and add grounding busses front and rear.
Postby KIM-P » 30 Mon May, 2011 8:18 am
I bought the Rebel wire VW bug universal kit. So far Ive only had to lengthen the backup wire and the oil pressure wire but I just got started. This harness has larger then stock gage wire and just barely fit in the 3/4 inch conduit Im using. At 186.99 plus S&H its still cheaper then the painless system by half. My total was $202.
Besides the EMPI universal harness looks too cheesy to me. And you get what you pay for.
Postby yoursurfer » 30 Mon May, 2011 10:26 am
which rebel kit did u buy the part number?
yoursurfer
Postby Aquabuggy » 30 Mon May, 2011 10:42 am
I used the buggy harness on three buggies builds the one sold under many names with 6 fuse & bag of wires, for a basic buggy it's all you need and comes with a very simple wire diagram. If your going to run a stereo with an amp or other accessories go with something else. no matter what harness you use you'll be adding ground wires and modifying a few things.
Postby KIM-P » 30 Mon May, 2011 5:43 pm
Go to rebelwire.com Part number RW401BUG. Descrition, VW bug-universal-12volt
