Indicator Lights
Indicator Lights
Postby CoryN » 20 Fri Feb, 2009 10:06 am
What indicator lights are y'all running?
Oil
Generator
High Beams
are the 3 I'm guessing are needed?
Cory
Postby Russhebert » 20 Fri Feb, 2009 10:37 am
I use an Autometer gauge for oil and just a small led for brights and turn signals.
Russhebert
Postby CoryN » 20 Fri Feb, 2009 10:39 am
I've got a gauge for both oil and power - do I not want to run the lights then? I was thinking it somehow required them?
Postby Russhebert » 20 Fri Feb, 2009 11:31 am
To pass inspection I believe it has to have a high beam indicator.
Russhebert
Postby jspbtown » 20 Fri Feb, 2009 12:24 pm
I seem to always run 4. A left & right blinker, a high beam, and the required alternator light.
Postby CoryN » 20 Fri Feb, 2009 1:02 pm
I didn't even think about blinkers.
So the alternater light is the one that is required, I thought there was one that I had to have for functionality.
Postby Greaph » 20 Fri Feb, 2009 3:28 pm
Oil press, oil temp, alt, fuel press, and engine overspeed....oh, and hi-beam.
This IS my sig......
Greaph
Postby jspbtown » 20 Fri Feb, 2009 3:29 pm
Alternator light is need to 'excite" the alternator. No LEDs for that one. It can be hidden if you like. You just need it.
Some dashes that might help you....
My old Manx:
A yellow buggy that I did kinda old school. Blinkers, high beam & alternator light built into the stock VW speedo. No tach. Just wipers & headlights & speedo.
A Bradley GT kit car I did. I eventually used stainless steel trim screw washers around the LEDs to make them look more finished. I also had to run a regular bulb under the dash in series with the LED to make it work right:
A Porsche Speedster dash that used 914 gauges...they work perfectly. All indicators are in the gauges:
Postby CoryN » 20 Fri Feb, 2009 3:43 pm
I went with the Shark gauges - I'll be hacking up the dash tomorrow for those. I don't think I'll put anything else on the dash except those 5 gauges - find somewhere else to hide the rest of the goodies.
I like those seats in the speedster. I also like the ones that ThunderRanch puts in their Spyders - but I don't see them for sale anywhere.
Postby jspbtown » 20 Fri Feb, 2009 3:54 pm
Try www.speedsterowners.com.
You may have to register...but it seems like seats like those are always popping up.
Just took a quick look...there are several available....
Postby carlos del carpio » 21 Sat Feb, 2009 3:20 am
One thing I do with all air cooled, with the generator/oil lights, is the introduction of an in-line buzzer. Just fits in either the power or ground part of the circuit, whichever you choose..(same wires as the indicator lights...) if it lights up, you get a nice buzz, helps when you can't see the light on sunny days 8-)
Postby Jack Duncan » 22 Sun Feb, 2009 12:27 am
I like the buzzer idea. Where do I find one and what do I ask for? :?:
Postby wildthang » 22 Sun Feb, 2009 7:41 am
Hello Jack you can find them in the project section @ Radio Shack I also installed on turn signal
wildthang
