cylinder 3 not firing
Postby jordanj » 02 Thu Apr, 2009 8:08 pm
What would be the common causes of this? i checked the exhaust pipe and it was still cool to the touch,while the other 3 were hot.
jordanj
Postby Don » 03 Fri Apr, 2009 7:17 am
Check for spark and if that's good it's probably a valve. You can check the compression to confirm.
Postby Jack Duncan » 03 Fri Apr, 2009 9:07 am
Also, check plug wire to that cylinder for continuity from the distributor to the plug. Carbon wires sometimes break. :)
