I am having hell with a 2 barrel empi carb, started as stock jets, 137 and 145, running 2 rich. blowing out blue and black smoke and cuts out when i hit the back barrel. so i switched the jets all the way down to 115 and 120, still does the same thing, perhaps worse. i have an electric fuel pump it is the empi fuel pump for a standard carb. only puts out 1.5 to 4 psi
8degree at idle 32degree full advance at 3500rpm an i played with the timing
ngk plug cap at 28
compurie electronic ignition
it a 1835 motor
