is there some procedure for adjusting the shifter? I hooked everything up and thought I got very lucky when I cut the shift rod and shortened it. I have nuetral,first,third and reverse. I can't get it too stay in second or fourth. I rolled it back into the shop and while it's just sitting there you can shift it and feel it go into all the gears but when I back it out and start it up it won't stay in second or fourth. There has to be more to it than blindly cutting the shift rod and shortning it and putting it back together and everything working. That would be to simple.
later
Rick
