roll cage
roll cage
Postby Rick » 12 Tue May, 2009 12:39 pm
Has anybody built there own roll cage? What size pipe did you use? have you ever used a pipe bender from Northern tool? How does that work?
latter
Rick
Rick
Postby jspbtown » 12 Tue May, 2009 1:55 pm
The bender from Harbor freight is a pipe bender not a tube bender.
Without modification it will only kink the tube.
The modifications that are needed are on The Samba.
Neil at Hawkeye Buggies is a great source for a "show" cage. I used him for my Manx build.
Postby David Head » 12 Tue May, 2009 4:03 pm
I agree, Neil Decker at Hawkeye is the only way to go. He is not far from you. He is located in Hawkins, Texas
http://www.hawkeyebuggies.com/
Postby Aquabuggy » 12 Tue May, 2009 4:52 pm
Yea I built my own see it here http://www.texasmanxclub.com/bboard/vie ... php?t=1082
But it would be much less expensive to have Hawkeye or Texasbuggys build one for ya.
Postby Fred » 12 Tue May, 2009 6:45 pm
If you can weld there are some pretty inexpensive cages @ www,mooreparts.com in the off road accessories section. I've caged a couple of race cars and If you dont know the math for subtracting the curves you're in for some headaches. I really recommend at least buying a kit, believe me, you'll have plenty of trimming to do even with a prefab cage. JMO, Fred. P.S. they come with instructions and they're already notched!!
Fred
Postby matter396 » 12 Tue May, 2009 7:33 pm
i see you used filler over the welds on your cage can you do this if your gonna powdercoat and not paint?
Get out and Drive,
Mike
matter396
Postby ckolek » 12 Tue May, 2009 7:44 pm
no filler on powder-coat....
Postby Aquabuggy » 12 Tue May, 2009 8:38 pm
I think you can use JB weld as fill material and powder coat it.
Postby jspbtown » 13 Wed May, 2009 8:55 pm
Rick,
It wouldn't let me respond to your PM for some reason.
Here is the link:
http://www.thesamba.com/vw/forum/viewto ... ght+bender
roll cage
Postby Rick » 14 Thu May, 2009 8:28 am
Thanks I finally found it. I'll try that this weekend since it doesn't look good for flying. It will keep me out of trouble.
latter
Rick
Rick
filler
Postby Texasbuggys » 14 Thu May, 2009 10:16 pm
You can use lab metal and smooth it out and powder coat over it no problem.
Postby matter396 » 15 Fri May, 2009 7:44 pm
Lab Metal????
Get out and Drive,
Mike
matter396
Postby Texasbuggys » 16 Sat May, 2009 11:41 am
yep it is like a JB weld, is sandable and takes the electric charge to adhere the powder.
Postby matter396 » 16 Sat May, 2009 1:26 pm
where do you get lab metal????
Get out and Drive,
Mike
matter396
Postby Texasbuggys » 16 Sat May, 2009 10:46 pm
eastwood sells it and some fastenal stores
Users browsing this forum: No registered users and 17 guests
