Can't get my trans to quit leaking. I'm not sure what trans I have, but it's irs and the nose cone has no lip seal, just a bushing.
I've had it out twice. It seems to pressurize the case when I have to maintane higher speeds [ 60-65 ] for a longer distance. I try to avoid freeways because of this and my motor is just a 1641.
I've checked the vent hole on top both time to make sure it's clear. It always pukes toward the front around the nose cone-to-case gasket or out the shift rod which naturally goes in the tunnel.
The first time it blew was a trip from Fayetteville, Ar, back to Joplin, Mo which as all freeway. It slung grease all over the "firewall", trans and back of the motor. Of course, I know, wind had alot to do with the spread.
I think I have a freeway flyer tranny. I don't have alot of trouble maintaning 60 to 65. I can do the 70 mph but don't like it.
Thanks, all.
