Berrien Chassis's
Berrien Chassis's
Postby BrianB » 21 Thu May, 2009 4:39 am
Anybody have any experience with these frames? Any items I should look out for? I will be lengthening it to fit under my Bradley GT. Has anyone done any mods to them? Are they a quality product?
berrien chassis
Postby mike cook » 21 Thu May, 2009 4:47 am
had one qaulity is very good very rigid which I think is good are you going to legthen fiberglass floor or go steel
mike cook
Re: berrien chassis
Postby BrianB » 21 Thu May, 2009 5:37 am
mike cook wrote:had one qaulity is very good very rigid which I think is good are you going to legthen fiberglass floor or go steel
I'll be getting rid of the Fiberglass floor if anyone is interested. I'll be using Aluminum Diamond Plate that will be a little lower to the ground than the current floor.
Postby Texasbuggys » 21 Thu May, 2009 6:30 am
check your PM on the floor
Postby BrianB » 01 Mon Jun, 2009 4:19 pm
OK I have the chassis now I need to figure out the drive arrangement. Is this IRS or Swing? It looks like IRS but there is nowhere for the trailing arms to mount?
Postby Aquabuggy » 01 Mon Jun, 2009 4:46 pm
That's a really old style a swing axle torsion from 50's or early 60's
Postby Texasbuggys » 01 Mon Jun, 2009 10:14 pm
can be converted to an IRS setup
Postby BrianB » 02 Tue Jun, 2009 4:46 am
Texasbuggys wrote:can be converted to an IRS setup
Actually its better if it is Swing because the transaxle that was going to be going in the Bradley is swingaxle. Its already rebuilt ready to go. Thanks for everyones input.
Postby blackthree4me » 02 Tue Jun, 2009 12:06 pm
I would definatly put that FG pan up for sale
someone will buy it for sure
:D
Postby BrianB » 02 Tue Jun, 2009 2:20 pm
blackthree4me wrote:I would definatly put that FG pan up for sale
:D
You're not interested in it are you? :D After much thought I am going to build this buggy with the glass pan. In the future that may change but for right now I'll use it. The chassis under the fiberglass is really engineered well so I dont feel too bad with the glass for the pan.
