What got me thinking was being approached by some shriner guys to build them some buggy's. I told them that the cost would be between 10-15K. They ran
Now that I look at it, I think I might be better off buying a cherry donor beetle that runs and drives and cutting that up.
What does it cost? Really what does it cost? For those just starting and building a brand new car, this is a realistic spreadsheet. Please comment.
Donor 350
Brakes
Master cylinder 30
wheel cylinders 60
hoses 60
hardware 15
seals 7
bearings 20
cables 30
Hard lines 30
drums 250
Reservoir 10
switches 20
532
Suspension
adjusters 25
bushings 50
shocks 40
ball joints 60
tie rods 65
rag joint 10
caster shims 10
drop spindles 200
460
Chassis
Steel 100
e brake 30
shifter bushings 12
tranny mounts 30
cables 30
trailing arm bearings 60
paint 100
bolts 85
447
Tranny
seals 50
cv boots 20
70
Interior
Seats 450
carpet 100
gauges 250
shifter 25
steering wheel 125
Roll Cage 200
seat belts 125
1275
Electrical
switches 60
fuse box 45
wiring 100
misc terminals 40
heat shrink 30
wiper motor 50
headlights 50
taillights 50
battery and box 90
515
Body
Body 2000
Fuel tank 70
fuel fill 135
hose 15
clamps 5
fuel filter 5
fuel filter mount 12
windshield 180
steering column support 75
steering column 50
body gasket 15
wiper arms 25
wiper blades 13
2600
Engine
1600 dp rebuilt by me 900
carbs--used 40mm IDF's 450
exhaust 200
chrome 200
clutch 150
alternator 100
starter 100
2100
Wheels
rear 360
front 270
lugs 30
tires 400
1060
Misc
Paint 150
powdercoating 250
general misc 300
700
10109
