Jack Duncan wrote:We need pictures! Do you have the stock seat rail still connected to the floor pan? Mine were just spot welded to the pan. I used the rails, but on the Pro90 seat that I bought, the mounting is simple. Just drill two holes for the front, then attach L brackets to the rear slider. Drill a hole for each side through the pan. Bolt the seat on and you're done. Go to
www.procarbyscat.com and look at the Pro90 seat. The new seat does not need additional sliders, they're build in.
Jack Duncan wrote:Scat seats are low profile. I have them in my Manx style buggy. Anyway, on you seats there may be some tabs for front mounts. They should fit snug against the front of your existing seat mounting rail. You may have to fabricate some 90degree mounts from some angle iron to fit the rear.
I'll try to find those pictures of your seats. That should help.![]()
jspbtown wrote:Jerry,
I just noticed you are in Springfield...I am in Belchertown.
jspbtown wrote:That WAS my orange Manx. I sold it shortly after completing to a guy in Canada. I miss it terribly.
I do have a Deserter GT and an Aztec 7 kit car on either side of my shop, as well as a Fiberfab Avenger kit currently in my shop......tucked into the corner while I paint my brother-in-law's 69 Camaro. Thank God that will be done on Saturday so I can get back to working on fiberglass!
MURZ wrote:Neil at Hawkeye buggies or Sparky @ Texas buggies can bend one up for you
