My buggy came with a oil temp gauge with the sending unit attatched to the lower rear of the engine near the crank pulley. Cruising arround at 55 mph brings the temp up to 210-F , running 65 mph brings the temp to 230. Knowing that babbit (the soft material on the bearings) fails at 180 degrees F , these temps bother me. Is this something to be concerened about and what is the max oil temp? Or should I just yank the oil temp gauge out and throw it away?
Im running a stock doghouse oil cooler with a slightly modified engine and 25" tall tires in the back. At 60 mph the tach reads 3200 rpm
