So I'm getting ready to bleed the brakes Saturday night, and adjust all the stars to get the brakes close, then get in to pump the pedal, and pump once, tight, pump again tighter, pump again and all the way to the floor. The second brake light switch blew all apart and drained.
First question is this common, or did I just get a bad switch. Second question, with a dual master and the volvo resevoir with the separate chambers, shouldn't I still have had some pedal for the other cylinder? Isn't that the point of a dual master?
