Radio Antenna
Radio Antenna
Postby bobby hinman » 22 Tue Sep, 2009 8:05 pm
I installed a radio in my buggy. any ideas on the location of an antenna?
bobby hinman
Postby GregR » 22 Tue Sep, 2009 8:18 pm
You could always run a CB antenna off your rear cage...give it that desert buggy look...
Postby yoboy » 22 Tue Sep, 2009 8:25 pm
Our green buggy has an amp'd. antenna mounted up underneath the dash. Did not want to drill holes in the buggy body.
antennae
Postby matter396 » 22 Tue Sep, 2009 10:39 pm
Yeah I had a hidden antennae under the dash of a Nova I had. It worked great, just like the one I believe Jack is running. Summit sells them and not very expensive, I am gonna run one on my buggy.
Get out and Drive,
Mike
matter396
Postby Jack Duncan » 22 Tue Sep, 2009 10:48 pm
I got mine at Pep Boys. Works! :)
Postby bobby hinman » 23 Wed Sep, 2009 5:43 am
Under the hood would be the ideal spot
bobby hinman
Postby jspbtown » 23 Wed Sep, 2009 8:24 am
I agree. I used an antenna like this:
http://www.carshopinc.com/product_info. ... d/9206/HAB
On a Bradley project I did.
Postby KIM-P » 25 Fri Sep, 2009 8:38 pm
Got mine from auto zone the rubber style tye wraped it under the dash.Worked great!
Postby Jack Duncan » 26 Sat Sep, 2009 8:18 pm
Mine is held in place with silicone. :)
Postby CoryN » 26 Sat Sep, 2009 9:49 pm
My buggy is too loud to ever hear a radio
Postby Jack Duncan » 28 Mon Sep, 2009 4:30 pm
That's true, but it's a good selling point if that day ever comes. :)
Postby buggieBob » 05 Mon Oct, 2009 7:19 am
I used an antenna with a amplufier built in at mounted under the hood I got it from a HI PRO Auto It works greate
My name is Bobby and I'm a buggy-aholic
buggieBob
Postby matty101_vw » 08 Thu Oct, 2009 7:37 pm
I recently just put a radio in my buggy, I just ran it down the side of the frame, works great! But on my buggy you cant see it unless your really lookin for it. ;-)
matty101_vw
Postby Jack Duncan » 09 Fri Oct, 2009 10:07 pm
Inside your side pods is a good hiding place for things like that. Another good reason to have them. :)
