Center mirror
Center mirror
Postby CoryN » 30 Wed Sep, 2009 5:52 pm
So I got the standard issue billet mirror for the windsheild but I can't get the angle I need. I'm thinking of grinding a bevel on the mount to get enough angle. Anyone else had this problem?
Postby BrianB » 30 Wed Sep, 2009 7:03 pm
Got some pics to show your dilema? 8-)
Postby CoryN » 30 Wed Sep, 2009 7:27 pm
If I adjust the mirror as high as it will go all I get is a good view of the rear seat. It needs to go higher. I think if I grind off the part that glues onto the windsheild at a forty-five I can get enough angle
Postby CoryN » 30 Wed Sep, 2009 7:29 pm
As most buggies have the same angle on the windsheild it might be a common problem
Postby jspbtown » 30 Wed Sep, 2009 7:53 pm
Can you flip it over or rotate the mirror 180 degrees?
Postby Bill K » 30 Wed Sep, 2009 7:57 pm
I had the same probem. I think the mount holding the mirror ball is pewter. I just carefully broke out enough of the top of the mount to allow the angle I needed.
Postby CoryN » 30 Wed Sep, 2009 8:12 pm
That's what I thought. Looks like pot metal. I figured a few passes on the belt sander will get me there
Postby Aquabuggy » 30 Wed Sep, 2009 8:25 pm
I used one of those on my first buggy, had the same problem I hit a couple times with a file, problem solved.
Just an FYI for the next guy buying a rear view go with B & K they cost a little more but well worth extra coin.
Postby Bill K » 30 Wed Sep, 2009 9:22 pm
And not only does B&K sell top-of-the-line quality, they are also one of the proud sponsors that helps support our Club.
Postby CoryN » 30 Wed Sep, 2009 9:36 pm
I know I plan to get my side mirrors from them. Ijust piggybacked the mirror with another parts order. And I put all my tickets in the drawing for the one at buggy blast but didn't win :(
Postby Rick Leddon » 04 Sun Oct, 2009 7:03 am
Hi Cory
I used a belt sander on my, came out fine.
Rick
Rick Leddon
Postby CoryN » 04 Sun Oct, 2009 8:19 am
Yep I did the belt sander too and it took about two minutes and worked just fine
Postby BrianB » 14 Sat Nov, 2009 8:14 am
So are most of you using the mount that clips over the frame or are you using the glue on :?:
Postby CoryN » 14 Sat Nov, 2009 8:30 am
I don't think I have seen anyone with clip on centers. Obviously the side mirrors are
Postby BrianB » 14 Sat Nov, 2009 9:48 am
I wonder if you could see anything from it if it was mounted on the dash? :roll:
Postby Aquabuggy » 14 Sat Nov, 2009 10:14 am
BrianB wrote:I wonder if you could see anything from it if it was mounted on the dash? :roll:
Probably not, wouldn't hurt to try it though.
Postby BrianB » 14 Sat Nov, 2009 10:44 am
I guess it would depend on the rake of the buggy. I'll look at that when I get home today.
Users browsing this forum: No registered users and 18 guests
