TRW steering box....grease or 90wt oil
Postby David Head » 10 Wed Mar, 2010 11:04 pm
I need to top off my TRW steering box.
Grease or 90wt oil. What's your preference???
sb
Postby mike cook » 11 Thu Mar, 2010 7:38 am
I use grease our cars are lighter then stock and less chance of leaking if your seals are bad I have part # for new seals
mike cook
Postby Bill K » 11 Thu Mar, 2010 9:00 am
I've got a TRW box and have a bad leak around the shaft to the steering wheel. How hard it that seal to change out?
steering
Postby mike cook » 11 Thu Mar, 2010 9:05 am
not bad at all I took my box apart cleaned it really good powder coated it put in new seals and filled it with grease
mike cook
sb
Postby mike cook » 11 Thu Mar, 2010 9:07 am
here are the brand and part #s large seal SKF 562828 small seal SKF 6405 hope this helps others to get seals in the future
mike cook
Postby Bryan Porter » 11 Thu Mar, 2010 9:10 am
90wt oil is what is called for and has always worked well for me.
Postby Bill K » 11 Thu Mar, 2010 9:29 am
Mike, where can you get the seals?
Postby David Head » 11 Thu Mar, 2010 10:44 am
Not to step on your toes Bryan, but Mike, are you just using bearing grease???
sb
Postby mike cook » 11 Thu Mar, 2010 2:20 pm
you can get the seals at any place that sells bearings and seals or some napa stores can order them just check around, the grease I used was for wheel bearings.I have a friend that just uses STP and swears by it for years says it clings to the bearings and shafts better then oil or grease!!!
mike cook
Postby Jack Duncan » 12 Fri Mar, 2010 12:30 am
I once had a 56 Ford pickup with a loose steering box. I mixed STP motor honey with 90w oil (half and half). Worked like a champ! It really tightened it up. :)
sb
Postby mike cook » 25 Sun Apr, 2010 1:38 pm
I have an extra set of seals if anyone needs them $15.00 shipped paypal this is for 2 seals for both shafts
mike cook
