Front end question
Front end question
Postby carlos del carpio » 10 Fri Mar, 2006 10:31 am
Alrighty, it's front end weekend for meeeeeeeeeeeee, folks!
How much goop/grease is needed for the leaves? I don't think I need to FILL up the tubes with grease, as they'd leak out from the adjusters...so, how much?
Thanks, folks!
Postby David O' » 10 Fri Mar, 2006 12:48 pm
Just a light swipe with a grease covered rag is enough! Too much makes it too hard to align them into the center adjuster!
Postby carlos del carpio » 10 Fri Mar, 2006 8:54 pm
Thanks! wish me luck! yay! front-end weekend
Postby carlos del carpio » 11 Sat Mar, 2006 4:36 pm
Pant...Pant...I tried working on the front end today..but it's.....
100 freakin degrees!!!!!!!!!!!!!
Your down south right?
Postby Patrick » 11 Sat Mar, 2006 7:40 pm
We worked on the Trans and the rear brakes. Put the Trans in and worked on placing all new parts in the rear brakes. Was just fine. We had a breeze and it was over cast for a bit. It's front end work for us tomorrow on Sunday.
Patrick
Front leaves
Postby Texasbuggys » 13 Mon Mar, 2006 2:38 pm
Hey I am feeling that heat Carlos! I put together an adjustbale beam with air bag this weekend! It was freaking hot man! Oh and David O check your mail my man!
Postby richard king » 18 Sat Mar, 2006 5:11 am
You know that you make me SICK the weather here has not even goten up to 45 here i am tired of the cold :( :( :(
richard king
