Exhaust
Exhaust
Postby CoryN » 28 Mon Feb, 2011 4:43 pm
Who is running what and what do you like or dislike about it?
I need to change to something other than these dual cannons and am having a hard time deciding.
Thanks in advance.
Cory
Re: Exhaust
Postby GregR » 28 Mon Feb, 2011 7:24 pm
I really like the tri-Mil with Quiet Pak muffler I got from Doug at Qualitat. Ceramic finish seems to be holding up well so far.
Re: Exhaust
Postby Manx102 » 01 Tue Mar, 2011 12:33 am
I have always like the classic look of the Manx Sidewinder myself. I have had this one on since 2008 and it is holding up well. Still looks like the day it was put on.
Randy
Manx102
Re: Exhaust
Postby CoryN » 01 Tue Mar, 2011 8:40 am
I agree, I really like the sidewinder also.
Re: Exhaust
Postby BrianB » 01 Tue Mar, 2011 9:14 am
One suggestion I have is to buy whatever it is you want in raw form and have it Ceramic coated locally. The factory coating tends to not last very well from what I hear on the Dramba.
Re: Exhaust
Postby staggerwing » 25 Fri Mar, 2011 9:54 am
That seems to the case with the dual bazookas (Tri Mill) we're running. The ceramic is not holding well.
Re: Exhaust
Postby GregR » 25 Fri Mar, 2011 10:32 am
If it's surface rust and not rust under the ceramic. Try some Mother's metal polish...thanks to Bryan for the tip.
Re: Exhaust
Postby ckolek » 25 Fri Mar, 2011 11:06 am
I talked to the guys at tri-mill after fredericksburg last year and they told ne to use fine steel wool if polish did not remove all rust or discoloration .
