where to find tubing insulation for 1.5" tubing (sand rail)
Postby wildwestrider » 30 Wed Mar, 2011 10:17 am
I checked Lowes yesterday,...no luck. They only had 1" max diameter. Any suggestions on where I can find foam rubber pipe insulation sleeves that will fit the 1.5" tubing on my sand rail frame? I'm in Cedar Park/leander area.
Brian
wildwestrider
Re: where to find tubing insulation for 1.5" tubing (sand ra
Postby Ken » 30 Wed Mar, 2011 10:57 am
Int he fall you can probably find it at any home improvement store. I find smaller stores like and ACE or TRACTOR SUPPLY often have such items when the big guys are changing their selves around. Or lots of online choices and you can find something other than black, if you desire.
I have ordered a lot of material from these guys in Arizona.
www.Chirco.com/BarPadding
