Picked up this VWC Fiera Body w/chassis and trans last weekend. It needs a LOT of work, but I've wanted to teach myself to work with fiberglass for a while and I need a good excuse to use up some of the welding wire that has been sitting around waiting for a project.
The Chassis looks to be a '62 with a link-pin front and swing-arm rear, the pans are in rough shape, and I have no idea what kid of condition the trans is in. Either way I expect it to be a fun project. I don't know what kind of time frame I will be need to get it done, I doubt I'll finish by the end of the summer, but you never know!
Here are some more pics of the buggy:
The car I intend to use as a 'donor' is a '74 Standard. I may end up only using the motor out of it and leaving the rest pretty much unmolested, but again, who knows? It hasn't been registered/inspected since 2000, and doesn't currently run, but it supposedly ran when it was put up in a garage (presumably when the previous driver went off to college since there is a HS parking sticker in the window) and looks to be in pretty decent shape. The Engine is stamped AE837XXX so it doesn't appear to be original to the car, but I plan to get it running while still in the '74 while I am working on the chassis and body of the VWC buggy.
More Pics:
