trans swap
trans swap
Postby vfr » 12 Sun Jun, 2011 7:01 pm
okay, i have an old split case trans (complete, i have a tunnel type swing arm tranny without the axles or tubes. can i use the axles and tubes from the boat anchor and put them on the more modern tunnel type swing arm transmission?? this is going on a f/glass dune buggy.
vfr
Re: trans swap
Postby KIM-P » 13 Mon Jun, 2011 3:49 pm
I really dont know if it will work,but it want hurt to try. Just use the old parts for a trial fit. Mock it all up and see if it will turn by hand. If it fits clean it up replace the bearings, seals and gaskets and go for spin.If it dont work then you'll have good experince on the next one.
Re: trans swap
Postby vfr » 13 Mon Jun, 2011 10:14 pm
thx, i'll give it a try.
vfr
Re: trans swap
Postby Vee Dub Nut » 13 Mon Jun, 2011 10:19 pm
I'm fairly certain that the tubes are interchangeable. Let us know what you find. If you end up needing different tubes, I've got a few sets around.
1967 Beetle
2000 GTi
Vee Dub Nut
Re: trans swap
Postby vfr » 13 Mon Jun, 2011 10:42 pm
thanks for the offer. i have a son at A&M corpus. he'll be a senior next sept.
little as----- goes surfing dang near everyday. now he wants my buggy. to save gas. yeah right. i was born in the morning but not this morning
vfr
Users browsing this forum: No registered users and 58 guests
