As I started slowing down I could feel the significant drag of the brakes. They weren't locked up completely but there was a lot of drag.
Called the wife, got the trailer and got it home...
Couple hours later, I unloaded her and brakes are working.
So I am thinking I had the rear brakes (stock drum) adjusted too tight and when things heated up they just got tighter.
But, even if this is so, why all the sudden? So I pulled the rear wheels off and started looking real close.
The only questionable thing I found, was a broken end of the adjuster spring clip.
I'm thinking, this is allowing the brake to loosen or tighten from vibration?
It looks like these just slide on, after removing one of the star adjusters.
Does anyone know for sure how this is installed/removed?
Anyone got one laying around, they would be willing to drop in an envelop and send me?
Any suggestions? Does this sound like anything anyone else has experienced and worked out?
I've got a disc kit to replace the rear drums, but I'm hoping for a quicker, simpler solution, so we can make the Classic.
