by johber41 » 11 Wed Sep, 2013 11:28 am
I removed the old seal and replaced it. Cleaned everything up and installed the new seal. Re-torqued the brake drum and topped off the trans-axle with 90 weight oil. We will see. I did not see anything out of order and I was careful with the new "O" ring seals. I guess we will see. Bryan, can you tell me if the wheel spacer is supposed to turn with the axle with the spacer turning on the rubber seal, or does the spacer stand stationary with the axle turning inside the spacer? That might explain a potential problem!
Thanks..John
- Attachments
- oil running down on back of tire.JPG (45.56 KiB) Viewed 8482 times
- Fouled Seal.JPG (48.14 KiB) Viewed 8482 times
- Old Seal Removed.JPG (47.5 KiB) Viewed 8482 times
johber41 on 11 Wed Sep, 2013 11:35 am, edited 1 time in total.
