Evening All:
I finally have the front suspension and alignment the way I want it on my manx buggy. New king pins, link pins, bushings. Went full cirlce taking out the needle bearings in the beam and replacing them with urethane bushings (way too stiff ride for me) and back to new needle bearings. The car drives straight and handles well.
I have radial tires p215/70r14 on the front AND 225/70R14 on the rear.
My question is how much pressure do you guys think I should be running in them.
I have found threads saying some of you are running lower pressure than recommended for the tire. I just think as light as the buggy is mabye I could get an even better ride at less than 30 psi. Just not sure how much less.
Thanks for your thoughts and have a great new year!!
Keith Thompson
