Check This Deer Lease Machine
Postby johber41 » 18 Sun Jan, 2015 12:33 pm
Got this mechanical beauty at an estate sale.....$150 worth of 1960 VW bus parts including a Type 3 Engine and a lot of steel.
Rear Reduced.jpg (66.91 KiB) Viewed 61369 times
Re: Check This Deer Lease Machine
Postby johber41 » 18 Sun Jan, 2015 3:32 pm
Took the bumper and engine cage off...everything heavy steel construction. Better look at the engine.
Engine 2 reduced.jpg (152.43 KiB) Viewed 61361 times
Postby staggerwing » 18 Sun Jan, 2015 9:14 pm
Cammo? Does it run?
Postby johber41 » 18 Sun Jan, 2015 10:50 pm
been sitting for about twenty years....the engine turns over and there is fairly clean oil in the crankcase...I am unfamiliar with this pancake style engine, but it is my understanding that the fan is the only real difference. The block is the same as the type 1, so once I learn the assembly, the rest should be easy. The drive train is from a 60 bus, but the pan looks like it was from a beetle. The intake is dual port, so the block may be a 1600 cc or so. Its an adventure! Stay tuned!
Postby Bryan Porter » 20 Tue Jan, 2015 11:58 am
With the gear reduction trans that thing could plow your garden. :D :D :D
What are your plans for it.
Postby johber41 » 20 Tue Jan, 2015 2:39 pm
Really no plan Bryan...they kind of gave it away for $150 bucks, I saw the type 3 engine and 1960's pan with beam, saw the potential for using the some of the parts (cage and front push bumper). I thought of getting the engine cleaned up and swapping it for other stuff. Interesting enough, just when I thought the wife was tired of me messing with my buggy, she sees this at an estate sale and buys it for me.
Postby Bryan Porter » 20 Tue Jan, 2015 5:45 pm
She's a keeper
Postby johber41 » 24 Sat Jan, 2015 3:47 pm
Engine is out.....interesting enough, no leaking, turns over, and you can hear compression. I believe everything is 6 volt, so I am familiar with that. Something to wrench on for late evenings. It is the medicine I need to relax after work. Hey Bryan Porter,the swing axles don't just go from the trans to the backing plate, there is some style of gear reduction at the backing plates...I will try and add a pic later. Check out the home-made intake system....carb is too dirty to identify yet. 3 more pics for you guys to see.
Front 3 Red.jpg (149.31 KiB) Viewed 61289 times
Rear Red.jpg (148.71 KiB) Viewed 61289 times
Intake Rear Red.jpg (155.37 KiB) Viewed 61289 times
Postby johber41 » 24 Sat Jan, 2015 5:28 pm
Looks like gear reduction at the wheel.
Rear Reduc 1 red.jpg (155.2 KiB) Viewed 61285 times
Postby Bryan Porter » 25 Sun Jan, 2015 12:48 pm
Yes gear reduction boxes
carb is progressive 2 barrel
type three intake made to go under floor of station wagon
is starter and gen. both 6 volt?
Postby johber41 » 25 Sun Jan, 2015 6:19 pm
not sure on the voltage yet....everything dirty and rusty. I am assuming that the donor car being a 1960 vw bus would dictate that the system is 6v..I do not know if it was upgraded. Interesting on the gear boxes,I guess the weight of the bus and the weak engine trying to move it down the road calls for this combination. Thanks Bryan...
Postby Ken » 25 Sun Jan, 2015 9:06 pm
Thats a really cool find John.
Postby johber41 » 26 Mon Jan, 2015 9:08 am
Thanks ken....I can learn a lot with little investment...this whole vw experience has been fun for me. I had no respect for them prior to owning my buggy
Postby staggerwing » 26 Mon Jan, 2015 9:12 am
Gear reduction looks identical to the 64 bus (ahem) that Sandy is hiding from you guys. It's 6 volt too!
Postby Ken » 26 Mon Jan, 2015 7:00 pm
johber41 wrote:Interesting enough, just when I thought the wife was tired of me messing with my buggy, she sees this at an estate sale and buys it for me.
When you think Karen is about at that point of drawing the line... remind her of the things that you wouldn't get without your buggy.
just casually hanging out with a couple friends for some de-stress time...
friends that acknowledge your accomplishment...
knowing that your problems really can make others feel better....
if these haven't persuaded the wife, you can always threaten her by reminding her of the other opportunities the buggy provides...
Postby johber41 » 26 Mon Jan, 2015 8:05 pm
Good one Ken.....it will take me a while to stop laughing to even come up with a reply! Richard did look excited to be able to rid himself of the Doom Buggy Award.....
Postby staggerwing » 27 Tue Jan, 2015 8:59 am
Good job Ken! Accurate, thoughtful, entertaining.. Who's that young lady on the horse? Some elaboration would be nice.
Postby johber41 » 28 Wed Jan, 2015 12:50 am
Have the intake and the generator removed. Block looks good, intake portals are clear.
Intake off reduced.jpg (152.96 KiB) Viewed 61272 times
Parts reduced.jpg (146.04 KiB) Viewed 61272 times
Postby Dave W » 28 Wed Jan, 2015 1:26 am
Richard - how could you forget John's Bandera honey "Rodeo Rose" - the fine lady on the horse!!! I still remember the drool dripping from John's mouth as she gallop towards his broken down - 6 volt buggy on that hot steamy September day.
It does look like fellow Manx Brother John's taste in Bandara women and buggies are the same - old & rusty!!!
Postby johber41 » 28 Wed Jan, 2015 4:14 pm
I was trying to get her attention, but Dave kept doing push-ups in the parking lot and she could not keep her eyes off of his man muscles. I did not have a chance for attention with a young chick-magnet like Dave around...even though there really were not any "chicks" there!
Postby johber41 » 03 Tue Feb, 2015 8:36 pm
Finally have the engine ready for the stand...turns out it is a "u" block, 1600cc. Had to utilize my tap and die kit to build a fan puller. Pressure washed the block and it seems like it is in great shape. Once I get my neighbor to help me lift it to the stand, I will pull the heads and investigate further.
Ready for Stand red.jpg (157.57 KiB) Viewed 61372 times
Pull Tool.jpg (149.35 KiB) Viewed 61372 times
Fan Shroud red.jpg (150.58 KiB) Viewed 61372 times
Postby staggerwing » 04 Wed Feb, 2015 10:02 am
Looking good John!
Any plans for the machine once you get er up and running?
Send some of that enthusiasm my way so I can get motivated fixin stuff on the buggy!
Postby johber41 » 04 Wed Feb, 2015 1:05 pm
Hey Richard.....I was thinking of slapping that engine in my buggy and bumping the horse power up. Got that advice from a good source (Bryan Porter) and I thought if I paint it up right, it might even look good. With the carb on top like that and that front shroud, it almost has the looks of a Ford V8. Just wrenching around on it and learning a little....I am wanting to go drive my buggy around but the weather has changed back to winter time here in Houston and this engine gives me something buggy-like to do and to post. The wife and I did get a good 3 hour cruise in last weekend, and drove around looking at houses in old League City and near by neighborhoods. It was perfect weather. Richard, did you ever get your pushrod tubes to stop leaking?
Postby staggerwing » 04 Wed Feb, 2015 2:25 pm
Nope - leaks like a sieve.. The cold weather slowed it down a bit but she needs some serious attention. Sides the pushrods, I think other things are leaking as well. An old friend once told me "drive it till it breaks, then fix it". As lazy as I've gotten these days, THAT MIGHT JUST HAPPPEN!
Postby johber41 » 05 Thu Feb, 2015 4:25 pm
Probably getting the leak from the oil cooler that stands over the driver's side cylinders, under the fan shroud. I had that experience thinking that it was the tubes.
Postby Ken » 05 Thu Feb, 2015 8:33 pm
http://www.vw-resource.com/6volt.html
I found this link, I'm not sure if it helps any but you know I just want to help out when I can... what...
Postby boltman » 05 Thu Feb, 2015 11:38 pm
and i will donate your hose clamps....thats a really cool ride man!!!!!
Postby johber41 » 06 Fri Feb, 2015 10:18 pm
Block looks good...going to freshen up the cylinders, get some push-rod tubes, re-assemble, and see if she will fire.
Cyl Polish red.jpg (152.73 KiB) Viewed 61331 times
Head Polish red.jpg (151.49 KiB) Viewed 61331 times
Waiting Tubes red.jpg (152.51 KiB) Viewed 61331 times
Postby johber41 » 10 Tue Feb, 2015 9:25 pm
Almost.......rebuilding the intake with fresh connectors and a clean carb. I want to build an add-on for my engine stand that would allow me to start the engine while on the stand. I have seen the engine stands people make with the partial bell housing, but without the trans to sacrifice, have any of you skilled builders found a way to simulate the mount for the starter?
Build 1 red.jpg (146.28 KiB) Viewed 61318 times
Build 2 red.jpg (143.9 KiB) Viewed 61318 times
Postby Bryan Porter » 10 Tue Feb, 2015 10:18 pm
Engine stand is way to unstable to start engine just shove it in the buggy.
Postby Ken » 11 Wed Feb, 2015 10:44 am
Don't listen to nancy boy Porter!!!
Be a man... just hold the starter up to the case and fire away.
Please set up the video recorder beforehand... um... at a safe distance, so we can see what an awesome engine you have. :D
Postby johber41 » 12 Thu Feb, 2015 12:33 pm
And ....you get to see it tear my arm off, and maybe see the engine hit the floor and stuff go everywhere! I'm not scared though! But, I have seen some stands on YouTube videos that seem to handle the engines just fine. Thanks for being in my corner Ken! By the way, this stuff is 12V so I will not need "the helpful link" you sent me.
Postby Ken » 13 Fri Feb, 2015 5:47 pm
So you're saying there won't be a video? :cry:
Postby johber41 » 14 Sat Feb, 2015 11:24 pm
Getting closer to the video Ken! You were right Bryan Porter.......the starter is 6V and the generator/voltage regulator are both 12V. I guess the builder married the 1960 pan-trans-axle to a more modern engine.
Intake on 2 red.jpg (151.89 KiB) Viewed 61552 times
Intake on 1 red.jpg (152.11 KiB) Viewed 61552 times
Postby johber41 » 21 Sat Feb, 2015 1:26 am
Thank goodness for the front pulley......figured out how to start it on the stand. Making use of an old table saw-gear reduction motor and a lever.
Front Start 2 red.jpg (153.37 KiB) Viewed 61541 times
Front Start 1 red.jpg (147.27 KiB) Viewed 61541 times
Postby johber41 » 21 Sat Feb, 2015 1:49 am
Postby staggerwing » 23 Mon Feb, 2015 10:03 am
THAT'S JUST NOT FAIR! I'm at work and I can't watch this video till I get home cause they have Facebook blocked? I quit.. Well, okay, I won't quit, at least not today. It'll be the first thing I do when I get home though!
Good job on the rigging John! There's no way I could have come up with anything like that to make it work.
NANCYBOY? Oh, I can't wait to see Bryan again!
Postby johber41 » 14 Sat Mar, 2015 8:43 pm
Thanks Richard.....Hey Ken, here is the start up video on the Type 3.....started first rotation,its a weird version though with the distributor 180 degrees reversed and the Holley-Motorcraft Ford two barrel carb. Getting the carb rebuild kit was the hardest part.
www.facebook.com/video.php?v=1735653263 ... =2&theater
Postby Ken » 15 Sun Mar, 2015 9:59 am
Dang John that's really cool stuff. And I'm actually happy it wasn't more "eventful"... although I'm sure you understand that the opportunity of a more entertaining video sounded very possible. Hmmm... there wasn't any out -takes were there? You going to put that in your buggy or what :?:
I got the rail out a couple times this weekend, man Saturday was just a perfect buggy day. She ran real good. Give her a bath and she's ready for buggy season :!:
Can't wait to see you bums at the Classic.
Postby johber41 » 17 Tue Mar, 2015 10:35 pm
Going to keep it as a spare....runs great, just weird in the settings. The stand was plenty strong to support the start up.
