Transmission /engine mount
Postby Buzzfagan » 12 Tue Apr, 2016 9:39 pm
Can you all tell me what I should do to the rear of this transmission before I mount the engine. Sandblast, clean with water, lubricate, etc?? I am a real newbie.
Also. What bolts and where do you get them to mount the engine?
Re: Transmission /engine mount
Postby Bryan Porter » 13 Wed Apr, 2016 3:24 pm
new mounts ,clutch,throwout bearing,lub input shaft,and starter bushing
Postby GregR » 13 Wed Apr, 2016 5:46 pm
knowing your location would help us guide you to a shop that has or can get the needed parts.
Doug at Qualitat in Grand Prairie is great. Not sure about other areas other than a mail order house.
Looks like it just needs a good cleaning. Don't think I'd sandblast it, elbow grease, degreaser and water will work. And other than the input shaft at the trans itself,
nothing there should need lubrication.
Postby Buzzfagan » 15 Fri Apr, 2016 6:39 am
Thanks guys. I am in Georgetown (just north of Austin). I will update my profile. Any one you know down here?
