So I am sure this has already been covered numerous times but the more I read the more confused I get. Can I please get some straight forward simple and specific advice on the specific types of grease I need and where each type should be used to totally rebuild my 64 beetle/manx buggy. It is a king pin/link pin swing axle.
I am going to be removing and greasing the whole car. I am doing the whole front end including taking out the leaves and regreasing, replacing the rear spring plate bushings inner and outer and every piece of rubber I can find. Also I will be putting on all new boots, converting to disc brakes and repacking bearings, etc.
I am using red urethane bushings everywhere and I need to know how to grease and install them so they do not squeak down the road. And which type of grease will not break them down. I have even read a suggestion on using anti-seize on them? Do I do that and grease? What type of each? Do I even grease the red urethane "bumpers"and "supports"on the fron trailing arms, back cone shaped ones, transmission mount,etc?
So what specific type of grease and which specific type for each parts of the assembly and how to apply it the correct way would be very helpful. What all do I need to grease as I put together everything?
Also, after it is all installed what type of grease do I use in each of the different zerks? Different type for different parts of the car?
Thank you for your help!
