So I am trying to decide which wheels and tires to get for my Manx style rebuild.
I have decided on 15x10's for the rest and I want to get the widest I can for the front. I already purchased some 15x5's for the front based on what the vendor I purchased them said. I really would like a larger width for the front but my vendor says that if I go any wider he is concerned with the tire rubbing on the chassis/suspension/fiberglass. I have no problem returning what I have and re-buying something bigger if it will work for the front.
Does this sound right? Do you think I can go wider for the front? Any help or advice would be great.
I don't know how to tell what to order to be safe so when I show up to discount tire with the buggy and wheels I know what to order and what will work and not rub.
I am going to try and get the largest possible street type tire (like BF Goodwrench Radial TA) that will fit on the wheel and fit the car correctly without any rubbing.
Here are the details of the 5 lug VW pattern I am going to use:
15x5 - 2 7/8" back spacing
15x6 - 3 1/4" back spacing
15x7 - 3 1/2" back spacing
15x8 - 3" back spacing
15x10 - 3 1/2" back spacing
