Somewhere I saw some adapter plates you could bolt on the end of your swing arms and bolt back to your axle making the swing arm be attached to axle lower than original. Their purpose was to lower the back end.
Has anyone seen these, and if so, where can they be gotten?
I also saw where can buy adjustable swing arms.
My question in both cases is: Does using either of these allow you to lower the rear without affecting the camber?
