by johber41 » 11 Tue Dec, 2018 2:06 am
There has not been a build or repair thread in a while so I thought i would share some interesting experiences.
Preface:
A log time ago (2008), but not far away, I was gifted a 1966 Manx style dune buggy built from a 1961 donor Beetle with a 1200 CC, 40 horse engine. The car was under a tarp in my neighbors yard and it had not been running since 1985. Everything was dirty and seized including the engine and trans. The car had not been attended to for many years with the tires flat and rotten and parts of the engine rusty and rotten. I had little or no experience with Volkswagen, being from Detroit left little room for foreign car hobbies, I did not understand the heat risers on my 1200 and why they were necessary. I cut the rotten riser off after attempting to patch them with copper. The whole tube was plugged anyway.
Jump Forward:
Lets get to 2018, the Buggy Roundup, and I noticed that I was getting hesitation on acceleration and asked a very competent buggy man what he thought it might be. The talented Mr Porter explained that the hesitation was likely from a bad, or miss-adjusted accelerator pump in my PICT 30 carb.
Carb investigation:
Upon getting back to Houston, I watched a lot of You Tube and then attempted to rebuild the carb. Everything went well and the was put back in and the same problem existed. i checked timing, valve lash, etc but could not cure the problem. Then I saw IT........a fuel drip below my intake just below the intersecting down pipe to the horizontal delivery system. I thought for sure I had a leak there causing air to be sucked into the intake. I also saw in a information video that the heat risers on the intake were necessary to stop fuel from puddling at the bottom of the down tube of the intake, as the fuel causes a cooling affect as it expands leaving the carb.
attached is a pic of my intake heat risers when I first tried to fix them....
- Attachments
- Warmer Line Repair.JPG (113.14 KiB) Viewed 36200 times
