Speedometer location
Postby garthom » 22 Mon May, 2006 6:51 pm
You Texasbuggy owners a question. Where is the best location on dash to mount speedometer? I have a 73 Super beatle speedometer & want to know if it will interfere with wiper motor or arms. How about speedometer cable?
Improvise, Adapt, Overcome
garthom
speedo
Postby Texasbuggys » 22 Mon May, 2006 7:27 pm
Gary, are you required to run electric wipers? If not I can offer you a cool clamp on mount that is easily removable. No wires and interference problems. I have installed the super speedo with no problems, center the speedo and drop down as low as you can without cutting thropugh the bottom of the dash. Of course double check rear clearances. Also two types of wiper motors so you need to check which you have to clear the speedo.
Ill
Postby Texasbuggys » 22 Mon May, 2006 7:28 pm
I am going to have another kit coming up your way soon!
Postby blackthree4me » 23 Tue May, 2006 7:25 am
FYI
here in Texas the guy at the inspection station told me that if there were holes in the hood for wipers that the wipers must be in that location to pass a safety inspection
just some info
Postby carlos del carpio » 23 Tue May, 2006 12:52 pm
only if a windshield is installed...
yep
Postby Texasbuggys » 24 Wed May, 2006 6:42 am
In Texas no windsheild- no wipers required.
