shifter linkage
shifter linkage
Postby Russhebert » 01 Sun Oct, 2006 5:22 pm
Is there a special way to put shifter tube in place. I have trouble getting my buggy in 1st and 2nd gear. Not all the time but a lot of times.
Russhebert
Postby David O' » 02 Mon Oct, 2006 12:16 am
The method of doing that depends upon the style of the shift rod connector. Is it a late model or an early model?
Postby Russhebert » 02 Mon Oct, 2006 5:39 pm
I am not sure it is the one that is retangular with a pin that goes through the bushing to hold it on the shift tube and it slides over the shaft on the trans and is held in place with a small bolt. Hope this helps.
Russhebert
Postby carlos del carpio » 03 Tue Oct, 2006 1:20 am
Sounds late to meeeeeeeeeee
Postby David O' » 03 Tue Oct, 2006 1:40 am
Put the shifter into first gear and loosen the whole thing up and see if you can move the shifter to the right or left and get the thing to go into the gears.....if not warp the shifter connector in the direction that it need to go to get it to do that.......first of all, make sure you don't have loose or missing bushing.
