i am thinking about buying this rig and needed some opinions on it from what the owner is telling me it does not start pulling good till after 2k rpms and i would have to take it to a local shop to be tuned down does this sound true or not ?
1959 Dune Buggy (Manx Style) $4400 over $8k invested...
It is Texas titled as an antique vehicle, and has the original tag of the pan.
This car is a total restoration, almost every parts, cable, wire, and bolt is new! This car has won first place in local car shows.....
1776cc Engine, Dual Kadron Carbs
Custom Heads-Chromoly Valves, Hardened Keepers, Dual High Rev Springs, 1:1.25 Bug-Pack Rocker Arms, New Style Bosch Alternator, 009 Bosch Distributor, 1.5 quart Deep Sump Oil Pan, Killer Bee Tig Welded Race Fan, Aluminum Camshaft Pulley
Swing Axle-Richmond 4.86:1 Ratio Gears, Bug-PackTorsion Bars, Kennedy Clutch Kit, Urethane Bushings, Off-Road Transaxle Strap, Camber Compensator,
Empi Short Throw Shifter, Bilstien Shocks, Front Ball Joint Adjustable Suspension Raise to 1.5 in, Welded Seams & Extra Gussets, 3in Body Lift
Douglas Aluminum Racing Rims, Body is Rhino Lined, Racing Seats w/ Five Point Harnesses, Hidden Marine CD Stereo and Marine Speakers.
