guys i got an question i hope someone can help me out. ive got a berrien chassis im trying to mock up and get brackets welded before i send it for pwdercoat.they sent a tube for the throttle cable to run threw,but i cant figure where to mount the thing.I see where it mounts at the rear,but where does the cable enter at the front?Im going with a peddle asembly by cnc not the stock unit. there is a bracket where im assume the peddle assembly mounts at the right center and a master cyl mount that ill have to remove for the cnc unit to mount. also the shifter and e-brake mount directly to the fiberglass floor.Is that strong enough to suport these or do
i need to reinforce them with steel?
sorry for the long post thanks
capmike
