I need to replace the grease seals on the front beam and was just going to use the "rubber torsion grease seals" as replacments. The local supplier here only has urethane until next weekend, so I searched "urethane" at aircooledparts and found a nice assortment of possible replacements including this:
"Urethane bushing kit for ball-joint front ends. This is the "short" kit for just the outer ends of the beam."
Questions are: do these guys take the place of the needle bearing sets in the torsion tube ends? if they do, do they come in black and are they a good replacement for the rubber seals.
thanks for the help...
