Eliminate torsions...use coilovers?
Postby tjheller » 31 Wed Jan, 2007 6:59 am
These buggies are light and bouncy with the stock stuff. Is it feasible to remove the torsion innards and use external coilover shocks? Is this a stupid question?
tjheller
Postby David O' » 31 Wed Jan, 2007 9:05 am
You can't remove the torsions, due to the fact that they hold the arms on, in the front!
Postby mufasa » 31 Wed Jan, 2007 11:34 am
Then what do you do to soften the front to compensate for the lack of weight?
Mufasa Proud to be a Viet Nam Veteran.
mufasa
Postby David O' » 31 Wed Jan, 2007 11:40 am
You can remove sections of the tortion springs (but leave the ends and the middle all there). Brazing the ends and the middle together will require work, but it is a can do. Make sure you don't allow this to make any of the cross sections larger, and then slide the springs back in and reinstall the parts.
Watch out for the heat, though, you don't want to get the strength out of the springs.
Postby Mike & Mel » 16 Fri Feb, 2007 11:54 am
You can remove the torsion springs and run a through rod, then you can use the coil-overs.
Mike & Mel
Manx Club #2265
Texas Manx Club
One of T.O.P.s
Joe Poty Sand Rover
Mike & Mel
Postby mkparker » 22 Thu Feb, 2007 6:01 pm
Like this!
mkparker
