I'm bummed out
I'm bummed out
Postby tjheller » 12 Mon Feb, 2007 11:03 pm
Got my wheels, got the right stance, got new brakes and cables put on, this afternoon was the time to attempt to start it. (last registered in '90) Hook up some jumper cables to my truck and turn the key...raaaraawww, raaaaraaaaaw, rrraaaarrraaawwww. You guys know the sound. Something is bad wrong, sounded like grinding. Pulled the plugs and relieved a little pressure, but still spinning over slowly and it's not due to small battery...it was hooked up to my Powerstroke. Any ideas on typical problems?
tjheller
Postby David O' » 12 Mon Feb, 2007 11:33 pm
Did it have the stock aircleaner on it or not?
Postby tjheller » 13 Tue Feb, 2007 12:01 am
It was with the "box-o-parts" I got with the car, so I assume it was.
tjheller
Postby mufasa » 13 Tue Feb, 2007 12:32 am
You might check how much amps you are drawing, could be a bad starter.
Mufasa Proud to be a Viet Nam Veteran.
mufasa
Postby David O' » 13 Tue Feb, 2007 8:57 am
With the plugs out, try to turn the motor by hand and wrench. If it turns but is real stiff, put a little WD40 into each cylinder, (spray) and let it set for a few minutes. Then try to spin it again with the wrench. If it is better, reinstall the plugs and pour a SMALL amount of gasoline down the carb and try again. When it sputters, you can add more small amounts untill the carburetor can take over and feed the engine.
Postby tjheller » 13 Tue Feb, 2007 10:40 pm
I may have discovered the problem. The bushing that holds the starter nose is awol and I'm sure the bendix is deflecting, hence the grinding. Thanks for the suggestions.
tjheller
Postby blackthree4me » 15 Thu Feb, 2007 1:44 pm
thats it !!!!!!!!!!!!!!!!!
I went thru a couple bateries before i figured it out on my rail.
once you get the new bushing in it will spin fine. trust me
I would also put in a little lube like daveO said
if you got a oil pressure gauge put that on as well beofre
attemting to fire it up
spin it over till the pressure is good then try the starting procedure
Postby MURZ » 15 Thu Feb, 2007 9:19 pm
Stick an autostick starter in it and be done with the bushing issue.....forever.
Postby blackthree4me » 18 Sun Feb, 2007 12:14 pm
auto stick hun
I will have tio check that one out
the bushings do wear out so that is a good Idea
starter
Postby Texasbuggys » 18 Sun Feb, 2007 11:12 pm
Knock the old bushing out and run the auto, works great, a little more expensive but no more starter bushing blues.
Postby MURZ » 19 Mon Feb, 2007 1:43 am
Actually you can leave the old bushing in there....it won't hurt anything.
Users browsing this forum: No registered users and 12 guests
