OK, so it seems the buggy had gas that went bad because I let it sit too long. Had David O over and we thought we had that taken care of, good psark, no sticky valves, etc. The tank was pretty much empty and I put in about 4 gallons of fresh corn oil.....er, gas.
The buggy seemed to run great.
Fast forward to the dinner cruise at the Blast. I drove it to teh Civic Center from our motel room (after having been towed in the rain) and the farther I got into the trip, the worse the backfiring, spitting and sputtering....so I parked it and didn't take it on the cruise.
OK, Sunday now...towed it home, got drowned almost all the way to Waco then it started to clear. Got the buggy to the house and took it off the trailer. Idled pretty smooth, then I tried giving it some gas and absolutely no power. When I got to the garage I realized that it was running on 2 cylinders. Checked spark and it was there on all 4. So I let it idle while I unloaded the truck. After 15 minutes or so, it started backfiring and spitting. Haven't had a chance to do anything with it since then.
I assume I got water in the carbs while towing, I also assume I still have some really bad gas mixed with the fresh. I'll either drain it or get some Heet to remove the water.
Any other ideas?
Also, how can the engine run so well on just 2 and 4 with 1 and 3 being dead? I don't understand. Dual Kads, a pertronix ignition. Seems like 1 and 3 are getting the same fuel/air mixture as 2 and 4....anyone?
