Engine Fan Shroud Screen
Postby Classic Manx 71 » 15 Mon Oct, 2007 9:41 pm
Looking for good ideas on attaching the debris screen to the doghouse fan shroud. (See picture below.)
Is welding a sheet metal lip around the inlet hole the best way ?
What about clearance to the Manx body? Does anyone know the space measurement?
Thanks for any help you can give.
Classic Manx 71
Postby David O' » 15 Mon Oct, 2007 9:59 pm
Those will not fit a doghouse cooler, unles you weld a piece of metal to the back of the shroud. As for clearance, I don't think there is enough room to get it to fit.
Remember, these units were designed for the early shrouds....as they were made before the doghouse units were designed.
