Speedometer
Speedometer
Postby KIM-P » 25 Fri Jan, 2008 6:03 pm
I want to keep my speedo reading correctly. What is the higth of a stock bug tire?
Postby ckolek » 26 Sat Jan, 2008 9:09 am
im not sure of the height, but i think if you go to a tire shop and tell them what you need i bet they will be able to tell you the height,or atleast get you close..im runing aftermarket speedo on mine i had United speedometer calibrate mine with the tire and wheel size..
Postby Aquabuggy » 26 Sat Jan, 2008 9:29 am
Here's a link to Randy's ring & pinion, there is a tire height calculator at the bottom of the page.
http://www.ringpinion.com/Calc_RPM.aspx
