I've been working on Shrek a bit and one of the things I did was to replace the coil-over shock with stock to soften the ride. The rear end was sagging before but now it's bottomed out. Unfortunately I threw away the coil-overs (rusty) before I road tested and let the suspension settle. So, if I'm going to have any chance of making Buggy Blast with a running buggy I need to reindex the rear torsions (swing axle). I've read the articles but I've never actually done it before. I have tonight after work and tomorrow until an early afternoon departure.
I need a best guess as to how far to adjust because I'll probably only get one shot at it before I run out of time. The article on the Manx Club website (http://www.meyersmanx.com/garage/garage_suspend.htm) suggests a one spline adjustment on the outer end (8.17 degrees) which sounds like a lot, but then again, I need a lot. Anyone have a suggestion? Like I said, the rubber bumpers are at their stops but just barely. Any tips or suggestions appreciated.
Also, does anyone know the size and pitch of the spring plate cover bolts? I understand that having some long ones can help with reassembly. If I could pick some up on the way home that would save me some time.
