how much power is too much
Postby buggyryan » 08 Mon Sep, 2008 1:40 am
hi guys does anyone know how much power a type 1 trans will hold? and will putting in a super diff with billet side plates help fix the weakness inherent in the swing axle trans. i am going to be putting around 200 to 250 hp to it and didnt know if it would hold it. if not does anyone offer the 091 bus trans in a swing axle set-up
buggyryan
Postby Aquabuggy » 08 Mon Sep, 2008 6:59 am
Ryan, Check out this ad on VOSA, I think Darrell (Testbud) has just what you need and its in SA.
http://www.vosaclub.org/phpBB2/viewtopic.php?t=6960
Postby GregR » 08 Mon Sep, 2008 10:16 am
It has a lot to do with how you intend to use the HP.
Dump the clutch and the T1 trans won't last long. Preload it before take off and it'll last a little longer. Don't dump teh clutch at all and it should last many miles.
Postby buggyryan » 08 Mon Sep, 2008 9:30 pm
see thats the thing, i am planning on drag racing it also. i dont plan on dumping it so much as launching at a reasonable rpm, and thing standing on it 2nd thru 4th. thats why i was wondering if it would hold up to very much hp or if a bus trans would be a better choice right from the start.
buggyryan
Postby GregR » 08 Mon Sep, 2008 9:50 pm
think I'd go for the bus trans....or drop the $5k if I had it for a Mendeola
Postby buggyryan » 08 Mon Sep, 2008 10:10 pm
so a super diff and side plates wouldnt help the weakness problem in the type 1
buggyryan
Postby Aquabuggy » 09 Tue Sep, 2008 7:10 am
buggyryan wrote:so a super diff and side plates wouldnt help the weakness problem in the type 1
Ryan, Give Darrell a call and ask him, I thank the trans he has for sale was in his bug with a big a$$ VW engine, that easily turned over 8000 rpm if it held up to that it should be fine.
400 bucks is super cheap, the super diff alone is over $200.
Postby blackthree4me » 09 Tue Sep, 2008 5:39 pm
HMM Ricky Graffeo anyone.
I would call ricky
super guy and he is the authority around here
http://www.graffeogearboxes.com/index2.htm
Postby David O' » 10 Wed Sep, 2008 10:11 am
You might want to consider getting the axles replaced, as I've seen 1776's with dual 44's twist the axles completely into. (three times).
Postby Jack Duncan » 19 Fri Sep, 2008 12:39 am
Don't scare me David O' ! I just had a 1915 built and I'm using a stock trans. By the way, what is the difference between a stock trans and a freeway flyer? I have gotten several answers.
JD (White Bandit)
Postby Aquabuggy » 19 Fri Sep, 2008 6:58 am
Jack Duncan wrote: By the way, what is the difference between a stock trans and a freeway flyer?
3.88 r&p
Hello Jack, glad to see you made it over to the club web site. Who did you settle on to build your engine?
