leaking oil seal
leaking oil seal
Postby Rick » 16 Mon Mar, 2009 2:27 pm
Is it possible for the wheel seals to leak if the axle nuts are not tight enough or did I just get bad seals when I had the trans rebuilt?
Rick
Rick
Postby David O' » 16 Mon Mar, 2009 4:15 pm
Rick, they will leak if the wheels are not real tight.
Postby Jack Duncan » 16 Mon Mar, 2009 10:29 pm
I'm not sure about VWs, but new seals can leak. I've had that problem in the past. :)
Postby David O' » 17 Tue Mar, 2009 4:49 pm
Just my humble opinion, but I installed the seals and the backing plates on that transmission....and they won't leak if the wheels are tight.
Postby Jack Duncan » 17 Tue Mar, 2009 9:56 pm
Sorry about that! :oops:
